Skip to main content
Store Dynatrace settings with the settings SDK
2-min readPublished Sep 15, 2026
A new guide, Store Dynatrace settings, covers the Settings SDK (@dynatrace-sdk/client-settings), a single API client for reading and managing Dynatrace settings objects—from built-in schemas like builtin:maintenance-windows to your own app schemas.
What the settings SDK covers​
The environment scope targets environment-wide settings, while entity-specific scopes use Smartscape node IDs rather than classic entity IDs.
What you can do with it​
The guide covers three main capabilities:
  • Browse schemas—use settingsSchemasClient.listSchemaDefinitions to discover what settings schemas are available in the environment, and getSchemaDefinition to inspect a specific schema's structure, constraints, and supported fields.
  • Read and write settings objects—use settingsObjectsClient.listSettingsObjects to page through existing objects for a given schema, upsertSettingsObject to create one, getSettingsObject to fetch a single object, and updateSettingsObject to update it. Optimistic locking is built in: every update carries the version returned on retrieval.
  • Support interactive settings editors—the settingsInteractiveEditingSupportClient provides helpers for building settings UIs: generate a default value object for pre-populating a new settings form, or generate a human-readable summary string to preview how a value will appear in list views.
Tip
Read the full guide at Store Dynatrace settings.
