Skip to main content
Receive intents
  • How-to guide
  • 4-min read
You can allow other apps to send data to your Dynatrace App. An app can receive an intent with a payload that you can use to perform an action. For example:
  • Pin the result of a DQL query on a dashboard
  • Set up an alert on a metric from a DQL query result
  • Show details of an app (based on its appId)
To receive an intent, you need to do the following:
Declare the intents​
An app can handle multiple intents that you declare in your app configuration file inside the app.intents property. You define an intent using an object where the key of the object is intentId. It consists of the following properties:
  • description: A short statement describing the action. It appears in the Open with... dialog.
  • properties: An object where you can define every payload property and its corresponding data type. Every payload property is defined using the key of this object, and the corresponding data type is defined with an object with the following properties:
    • required: A boolean defining whether a property is mandatory.
    • schema: A JSON Schema object describing the shape of the property.
Note
If you want your intent declaration to be matched in the Open with... flow, you need to add one required property at least. This prevents overly broad matches.
If you only use explicit intents—which target a specific app and intentId—you can exclusively declare optional properties to support flexible cross-app navigation with dynamic payloads.
Here is an example of an app configuration with intent declarations:
app.config.json
"environmentUrl": "<Your-Environment-URL>",
"app": {
"id": "<Your-App-ID>",
"name": "<Your-App-Name>",
"version": "0.0.0",
"description": "<Your-App-Description>",
"scopes": [],
"intents": {
"view_host": {
"description": "View the host",
"properties": {
"dt.entity.host": {
"required": true,
"schema": {
"type": "string"
"view_query": {
"description": "View query",
"properties": {
"dt.query": {
"required": true,
"schema": {
"type": "string"
Receive intent payload​
After you declare the type of intents your app can handle, the next step is to receive an intent in your app. You can achieve this using the getIntent method from the @dynatrace-sdk/navigation package.
Note
To use intents, you need to install the @dynatrace-sdk/navigation npm package in your project.
Here is an example of using getIntent with React's useEffect:
import React, { useEffect, useState } from 'react';
import { Code, Paragraph } from '@dynatrace/strato-components/typography';
import { getIntent, IntentPayload } from '@dynatrace-sdk/navigation';
export const YourComponent = () => {
const [intentPayload, setIntentPayload] = useState<IntentPayload>();
useEffect(() => {
const intent = getIntent();
if (intent) {
setIntentPayload(intent.getPayload());
return (
{intentPayload && (
<Paragraph>
Received Intent Payload <Code>{JSON.stringify(intentPayload)}</Code>.
</Paragraph>
Things to know about the getIntent method:
  • The getIntent method returns an object of Intent type.
  • You can call the getIntent method anywhere in your Dynatrace App. For example, in App.tsx, a component, a custom hook, react context, and elsewhere.
Caution
If your app has routing configured, you need to create a route /intent/:intentId in your app to handle the intent using the getIntent method. The AppShell opens this route and passes the intent object synchronously. Your app won't receive the intent if this route doesn't exist.
Handle multiple intents​
Each type of intent has a unique ID. If your app handles multiple intents, you can target a specific intent using that ID.
Here is an example of handling two different intents using the getId method:
import { useEffect } from 'react';
import { getIntent } from '@dynatrace-sdk/navigation';
export const AnotherComponent = () => {
useEffect(() => {
if (intent?.getId() === 'share_chart') {
// for example: shareChart(intent.context);
if (intent?.getId() === 'view_query') {
// for example: viewQueryInTable(intent.context);
// … jsx and the rest of the code
In this example, if intentId is share_chart, the call is to a hypothetical method named shareChart. However, if intentId is view_query, the call is to a hypothetical method named viewQueryInTable. This strategy lets you perform different actions with different intents.
Still have questions?
Find answers in the Dynatrace Community
