Skip to main content
Send intents
  • How to
  • 3 minutes
Intents provide a way to extend your Dynatrace app's functionality. Part of that process is to send intents from your app to the receiving app. You might want to send an intent for several reasons, such as:
  • Pin a chart to a dashboard
  • View details of an app in the Dynatrace Hub
When you send an intent, the AppShell displays an Open with dialog to let you choose the app that will receive the intent.
This guide shows you how to define and trigger a send intent from your app. Before you start, familiarize yourself with the intents mechanism and its processes.
Time to complete: 10 minutes
1. Define the intent
First, you need to define the intent payload. An intent payload is a set of key-value pairs that contains information you want to share.
Define the intent payload using the IntentPayload type from @dynatrace-sdk/navigation as follows:
import { IntentPayload } from '@dynatrace-sdk/navigation';
// Intent payload definition
const intent: IntentPayload = {
'dt.query': 'fetch logs',
'custom.type': { foo: 'bar' },
2. Trigger the intent
You can trigger the intent from your app in one of three ways, using the:
  • <IntentButton> option
  • sendIntent method
  • getIntentLink method
The <IntentButton> option
Use the <IntentButton> for straightforward use cases where you want to trigger a declarative intent.
Execute the <IntentButton> from @dynatrace/strato-components/buttons as follows:
ui/app/App.tsx
import React from 'react';
import { IntentButton } from '@dynatrace/strato-components/buttons';
export const App = () => {
return (
<IntentButton
payload={{ 'dt.query': 'fetch logs' }}
options={{
recommendedAppId: 'dynatrace.notebooks',
recommendedIntentId: 'view-query',
Edit in Notebooks
</IntentButton>
The sendIntent method
Use the sendIntent method if you need more control than the <IntentButton> provides to trigger an intent from the @dynatrace-sdk/navigation programmatically. The sendIntent method takes an intentPayload and optional sendIntentOptions parameter.
Send an intent with the dt.query property using the sendIntent method as follows:
import { sendIntent, IntentPayload } from '@dynatrace-sdk/navigation';
const payload: IntentPayload = {
sendIntent(payload);
Open app without showing the Open with dialog
It's possible to bypass the Open with dialog and open the app directly.
import { sendIntent } from '@dynatrace-sdk/navigation';
sendIntent(
{ 'dt.query': 'fetch logs' },
Note
If you provide a non-existent recommendedAppId or recommendedIntentId, the AppShell will display the Open with dialog box, allowing you to select a different app.
Mark properties as required when matching the intent
When an app sends a complex intent payload, the Open with dialog shows every app capable of handling at least one of the payload properties. It's possible to narrow the list by providing property names that must be matched as keyProperties.
const complexRowData = {
'dt.entity.host': '<ID>',
'dt.entity.process_group': '<ID>',
'dt.entity.process_group_instance': '<ID>',
'span_id': '<ID>',
'trace_id': '<ID>',
sendIntent(complexRowData, {
keyProperties: ['trace_id'],
Use the getIntentLink method to create a static URL link that users can copy, share, and bookmark in their browser. The getIntentLink method takes an intentPayload and optional appId and intentId parameters.
Create a static URL link using the getIntentLink method from @dynatrace-sdk/navigation as shown below. This example shows how an app renders a URL using getIntentLink.
ui/app/components/YourComponent.tsx
import { getIntentLink } from '@dynatrace-sdk/navigation';
import { Link } from '@dynatrace/strato-components/typography';
export const YourComponent = () => {
const intentLink = getIntentLink({ 'dt.query': 'fetch logs' });
return (
<Link href={intentLink} target="_blank">
Intent Link
</Link>
Note
If you provide a non-existent appId, the AppShell will display the Open with dialog box, allowing you to select a different app. Provide an existing appId and intentId to bypass the Open with dialog and open the app directly.
Now, you have integrated the user flow from your app to other Dynatrace Apps by sending an intent.
Learn more
If you want to learn more about extending your Dynatrace app using intents, check out the Receive and Debug intent pages.
Still have questions?
Find answers in the Dynatrace Community
